Not sure if I could post it here or if I should have made a seperate topic, but since I see a lot of really knowledgeable people in this thread, here goes:
So via a Team Jumbo-Visma competition on Instagram, I won an Inscyd Power Performance Decoder test. Last weekend I performed all tests, seperated over 2 days. ±20" and ±12’ efforts on one day and ±3’ and 6’ on the other day.
At 67.1kg of bodyweight, I got:
20": 857W
2’30": 449W
5’: 365W
10’: 332W
Now the report estimates my VO2Max to be 72ml/min/kg, which seems way too high. My last lab test I came in at about 61-62ml/min/kg at a similar weight. Since I started triathlons 4 years ago, I've always tested (with a gas analyzer mask)/been estimated between 3800-4100ml/min. My VLaMax was estimated at 0.67ml/l/s which also seems really high given that I rarely do efforts <5’ (Olympic/half distance triathlete), except for the occasional race uphill on a group ride. I mostly focus on longer efforts and a lot more LSD/easy rides since I've always been a sprinter type.. I know I’m still a punchy rider but both of these values seem off. They estimated my anaerobic threshold to be 295W which seems right given that I averaged 292W for 44’ in a Zwift TT in April.
So for a lower VO2Max but the same AT/FTP, I would have a lower VLaMax? I guess more in the region of 0.5ml/l/s which is supposed to be similar to that of classics riders and olympic distance triathletes?
What could be the reason there's such a big difference between all of my previous VO2Max results and this one? I suppose it's not possible that I'm already so full of lactate that I can't reach the 72ml/min/kg for some reason? My max. HR is about 176 at age 28 so on the lower side but not sure if this is an idicator of some other limiter.
They calculate that for every Watt you need about 12.5ml of O2, is it possible that I'm more efficient than that and that this means I can reach these numbers with a lower VO2Max?
I've uploaded my report to WeTransfer if anyone wants to have a look
https://we.tl/t-zDoOzw7x3u (file was too big to upload as forum attachment)
I'm also fine discussing this further via PM.
