I've just fitted the Hubdoctor Pro Freehub Bearing kit to my Ksyrium Elites and noticed a lot of drag from the rubber seal fitted on the freehub adapter that seals between the freehub and hub body. Does anyone have any experience with this kit?
If I take this seal off, fit everything back on the bike and spin up the rear wheel it'll coast for a long time, so there's obviously very little drag in the freehub itself. When I fit this seal and spin it up again, there's a ton of drag in freehub, it tries to drive the pedals around and if I hold them still, the drag puts tension on the rear derailleur cage and causes the chain to sag. I've lubed the seal at both the interface with the Freehub Adapter and with the hub itself the same lightweight synthetic lube as inside the freehub itself, but it hasn't made much discernable difference!
Just wondering if anyone else has experienced this? Can I expect this seal drag to ease up after a couple of rides and is the bike safe to ride like it is with the chain sag when freewheeling?
