4. There are some things that have been discussed here that I was tempted to argue but just let pass. For instance, there have been comments that I sit too far aft on the saddle. I actually sit so far forward on the saddle that the frank and beans are forward of the saddle nose. The saddle is an ISM PN 1.1. I don't think I could sit any further forward on the saddle without falling off.
This is is how forward you can sit on the ISM PN1.1 without falling off the front. Not saying you should go forward if you donāt have issues, but sitting that far back makes that specific model actually quite a wide saddle which for most could lead to shaving issues.
I do wonder what problems you think might come up using 155 mm cranks based on just 1 guy saying āmehā. Not to offend you by any means but you and him are built totally different. He can use 172,5 mm and still feel not cramped, but you are already crunched and cramped in your fit. He is having a slim, well trained body and you are a bit heavier. Especially around the waist where the upper leg meets the upper body. You just want some more room in that area.
There is no power loss with the 155ās and experience learns that the higher cadence at first comes back to normal due to choosing different gears, etc.
Jeroen
