GreatScott wrote:
I see bike splits on this thread of 5:40 - 5:50 at Whistler with average power of 175w - 190w. For example:
5:38 at 186w and 170lbs (1.09 w/lb) - Owen
5:41 at 176w and 150lbs (1.17) - TriZag
5:44 at 189w and 165lbs (1.15) - GMAN
5:47 at 189w and 169lbs (1.12) - Greg66
5:50 at 176w and 157lbs (1.12) - Raf
My 5:56 at 198w and 178lbs (1.11) at Penticton leaves me scratching my head, wondering what I am missing. Perhaps Whistler and Penticton are comparable after all?
There is a lot more to it than just power-weight ratio,, and people usually use w/kg, makes the numbers seem bigger ;)
Position is a huge factor over 5-6 hrs racing. How you move around to drink and eat can make a difference. Did you stop at special needs, or blast through all the aid stations? At 178lbs, you are likely on the larger side compared to the other riders, either taller or 'thicker'. Times at Whistler might be faster due to the drafting, even for those of us that didn't draft. You get a boost every time you pass someone, 20-30 secs to follow their draft. If you pass 50 people in the ride, you can spend up to 25min in the draft. Penticton would have had less drafting due to the smalle field size. Whistler was also 2-2.5km short of 180km, adds ~4min to all of our times.
Also, can't forget the difference between power meters. Some might not be calibrated properly. Some just read higher than others.
I was 5:25 (including 2min stop). 214 ap, 231 np (1.08 VI). ~172lbs on race day, 1.25 w/lbs (2.75 w/kg).
