Answering you but just a general thought.
Our lube just makes it easier and is the best "easy" way.
If an athlete is willing to clean and hot wax every few 100 miles - that is better than applying our lube. 2nd best is our lube; 3rd Squirt lube.
If you are going to take the time to hot wax - then any of the wax and wax combinations are good. All very close - you don't have to over think it.
The biggest difference is the chain you start with. Our process makes the chain super smooth so its' fast and lasts a long time.
If we did not smooth the pins, plate and rollers I would not purchase a Connex chain for racing - maybe just the quick link. Its' a tight chain out of the box and takes a long time to break in on a bike. Our process fixes that so you get the smoothest chain and one that lasts a long time.
Most other chains are made loose out of the box. That is why they tested better in the often sited results from testing. Anyone could have taken a very used chain (of any brand) off their bike, cleaned it, lubed it and it would have tested better than all the others tested.
If an athlete wants a fast set up and did not want to purchase our chain due to the initial cost - I would recommend getting the loosest chain I could find and run it in for 75 miles to knock off all the high points - clean it - hot wax it every 150 miles - use it for a total of 750 miles and then get a new one and start over.
Testing: We have done a sh.t ton of testing over the last 15 years on all kinds of metal parts, components and systems. There are hundred's of 3rd party papers written on the process we use. Timken, REM, Modern Machine Magazine etc.. (Google - Isotropic finish treatment) have a lot of internal and 3rd party studies on their sites. No other company that sells you chains does what we do to them. I don't release our chain studies because chain systems are hard to do and I'm not going to tell our competitors how we do it.
So - chains are a 0 - 5.7 watt decision. Then the decision is money or effort. If you choose effort the delta between doing it your self and purchasing the best is about 2.5 watts. I hope that helps.
Dan Kennison
facebook: @triPremierBike
http://www.PremierBike.com http://www.PositionOneSports.com
