Let's assume that you already have all the best aero doodads and maxed out your "purchasing of speed". The only way to get faster now is to improve your position and your fitness. Let's assume for a second that you have already optimized your bike position.
That leaves fitness.
Q. How to take 10 min off your ironman bike split ?
A. Ride 3 RPM faster....in the same gears
At the surface this sounds really easy. 3 RPM, seems to be no big deal. But at 90 RPM, you have to now ride at 93 RPM in the same gear. So you'll go 3% faster, which pretty well means 9% higher power output. For someone riding in the 5:20 - 6 hour range, this is around 9-10 min faster.
I was thinking about this on my ride home last nite. So I played around and generally found that I could revv up another 3 RPM out of my body, but it was just a short 35 min bike commute.
This morning I tried it on a 3 hour 90K ride with 2800 ft of climbing before riding into work at 9 am. Whenever, I felt my legs burning and my RPM dropping, I stayed in the SAME gear and tried to spin 3-5 RPM faster. The interesting thing is that it was not super difficult, but I had to keep reminding myself to do it. If not, I kept sliding back to a "comfort zone"
Please note that this is different from dropping it into an easier gear and going 5 RPM quicker. The goal here was to stay in the gear that my legs were already "burning at" and add another 3 RPM.
Typically, my first instinct when things get "difficult" is to either go to an easier gear and spin quicker, or go to a tougher gear and perhaps grind a bit on a false flat downhill, but I rarely stay in the same gear and try to increase my RPM.
I wanted to collect some of your thoughts on this. If there was an "average RPM" guage, the goal would be to stay in the same set of gears for the entire ride and do the ride faster by "averaging" 3 RPM higher.
Bottom line, is that you are trying to squeeze out 9-10% higher wattage out of your body my spinning 3% or so higher in the same gears.
