This was in my daily fitness tip email. I personally like the "slam it against the ground"
A tacoed wheel has been bent into a taco-shell shape after some sort of crash. You unfortunately have no choice but to rebuild it with new spokes and a new rim. However, you at least can bang it back into some semblance of shape to ride back home or toward the nearest repair shop. To fix the wheel:
Be careful not to injure your hands as you do this. Also, if you're trying to repair a back wheel, try to not hit the cogwheel against the ground. The cogwheel is the fragile cluster of sprockets attached to the rear hub, which the chain goes through.
Once the wheel is somewhat fixed, you can ride on it, but you'll have to get it rebuilt eventually. You could buy spokes and a rim, to make the new wheel yourself, but if you're not good with tools or unfamiliar with bike mechanics, it's best to have a bike shop build you a new wheel.
- Remove your wheel by unscrewing the quick release bolt or loosening the nut. Don't slam the quick release mechanism against the ground.
- Hold the wheel parallel to the ground with the bend facing downward.
- Grip the wheel on either side of the bend and lift it up over your head.
- Bring the bent part of the wheel back down, smacking it hard against the ground.
- Repeat until the wheel looks fairly straight.
