Greetings All,
I was mounting my rear wheel to my DA after some cassette cleaning and noticed that the center mold line on the tire was not aligned/centered on the seat tube of the frame. This lead me to first compare the wheel to frame centerline and then to compare the gaps between respective rim brake surfaces and their chainstays. Which then lead me to ask myself, "How do I know that my rear wheel is perfectly centered (as humanly possible) between the chainstays?"
Assumptions:
How would you measure this to verify? The human eye can get close but without measuring we can't be certain.
Using one of these would help:
Or one of these to provide the measured value directly:
Knowingly trying to TT with my rear wheel skewed or off-center would bug the crap out of me. Have you verified by measure? How'd did you accomplish the task? Thoughts?
TIA,
Eric
Assumptions:
- The wheel is perfectly dished as verified by a tool such as my Park Tool WAG-3
- The alignment setscrews in the rear dropouts are correctly adjusted for wheel yaw vs. centerline of frame
TIA,
Eric
