michael Hatch wrote:
Having looked at a few tests on GCN and other places then I tried, for a lark racing Tri in MB shoes with spd's.
Bear in mind that my power output might at best be half of a true road bikers capability. MB shoes are easier to walk/run in, so mounting and dismounting is a breeze.
I have always put my shoes on in T1, and Race mounts are faster, because you can do a one pedal, leg over, without slipping.
I regularly run past a bunch of people trying to get mounted or trying to get their feet in after starting clipped in.
In T2 I can stop on the line and hop off while still moving. And don't have to spend the last K untying, taking my feet out and coasting.
sdp pedals are usually 2 sided, so you might even gain a few more seconds clipping in..
I also find they unclip better/faster, so the embarrassing "topple" doesn't happen so often.
Power loss is minimal (if any) I have tried on matching courses to find a difference.
And another bonus is if you have a problem (like a mechanical you can't fix) on an isolated ride you can walk (even jog) on MB shoes.
If manufacturers made a lightweight, (non leather) MB shoe that didn't cost the earth I would buy them in an instant.
You're half right. Mtb shoes and pedals have a two-way interface that allow you to clip in on both sides. And you can typically walk in mtb shoes easier than road/tri shoes with protruding cleats.
Otherwise, no. Just no. If you can do a flying mount to get onto your bike, you'll be significantly faster than attempting to clip in on one side then swinging your leg over the bike (& you've got a fair bit of risk that you'll come crashing down on the side you've first clipped into). It's why the itu, xterra, and now half of the long-course pro's - and age groupers - do it. And it's really easy to learn too! Also, with proper off-road tri shoes (or even road tri shoes with a cleat adapter) will allow you to do this kind of mount without having to worry about how you clip in/out with spd-sl cleats
