In Reply To:
Like I said its a small difference in any. One thing you have to realise is that the smoke in a WT is indicative of how much air is being displaced and moved. When you see the smoke part and stay continuous thats good. When you see the smoke become disrupted, thats bad. In both cases every part of the bike still is cutting through air, just because the smoke is parted before the seat tube doesn't mean that the seatube isn't cutting through air just as dense as the air that was being marked with the smoke. My guess is that from 0 - 10 mm you loose very little aero benefit. I'm still curious if moving to close, without any rubbing causes some power loses.
Styrrell
How could that cause power losses if there's no rubbing?
Personally, I put the wheel on my P3 a little further out than credit card distance. A lot of things flex under power. Even if a wheel doesn't rub on the stand, it may still rub on the road when you're weighting and powering it.
As far as the aerodynamics go, I think the only one around here who has actually tested it in a wind tunnel is Gerard. And I believe he claimed a while back that the wheel needs to be very close.
-- Jens
My latest book: "Out of the Melting Pot, Into the Fire" is on sale on
Amazon and at other online and
local booksellers
