So if you can have 15 degrees tilt and xxmm of vertical bar rise from the pads: how is vertical rise measured if you only tilt the pads and use higher extensions?
Doesn’t really matter for my race class, just curious.
I see some folks tilting the pad/bar together with a nicer part, then some only tilting the pads then using “hi rise” bars.
Bought 15deg spacers but they only tilt the pads. Didn’t realize when I bought it.
If the extensions thing is an option, I’d try that.
