I just bought a Blue Triad SL frame and a couple of Tririg Omega X brakes for front rear. Tririg website states that the Triad SL does accept omega for front and rear and in installation vid and directions I'm to remove the direct mount studs on frame at rear brake. Here is the problem.... They are super tight! Should I use heat (small torch) to heat up the stud which was probably installed with lock tight. Scary on a multi $K frame.
I've sent Brian at Mybikeshop.com the same question and he is checking as well but I was hoping for some Slowtwitch help too.
Thanks in advance.
Thanks in advance.
