So i decided to go with QuintanaRoo PR4
The Last two bikes that I had were 54 Felt DA and 54 Scott Plasma Premium with -17 (flat Sten) and 45mm raisers
The person from Quintana Roo suggested 52
I have long legs so I afraid the the size will be short for me.
What do you think?
QR sizes differently, the size number means stack. For most frames the size means nothing. The 54 Felt DA has 497mm stack. The 52 PR4 has 520mm, so it's a taller frame. The DA is a bit longer (~6mm?) but that is easy to accomodate.
How long is the stem on your DA?
Thank you mat, I think it was the shortest one, if I am not wrong 45mm or 50mm maybe 60mm, it was long time ago!
I tried to find the Scott stack that was the most recent one, but I couldn't!
With such a short stem you'd be fine on the 50, although you could run into toe overlap depending on how long your feet are, where your cleats are adjusted, and how long your cranks are. How tall are you?
I like the Quintana Roo bikes; good choice.
