imswimmer328 wrote:
I'm sure they won't fall apart under you or anything, but I wouldn't ride a budget carbon rim. There are just too many variables involved with making a brake track that stops well in any condition and is structurally sound. If I were you I'd try and find something like a used HED jet front wheel and a disc cover. In the meantime, you'll be able to tt just fine on whatever wheels you have stock
This.
A HED Jet 6 plus front will likely be just as, if not more aero, has a much wider internal allowing you to run tires at lower pressure, and aluminum braking surface will be superior to anything carbon. A disc cover in the rear will be faster, and be more stable. A covered rear wheel might be a touch heavy, but since the OP is looking for use on flat courses, it won't matter.
