rob_bell wrote:
I'm on the Panaracer team, so I'm sure you can guess what I'm about to say...
If you're unhappy with your current tire, I'd give the Gravelking SK 38 a try. It usually measures wide on modern rims. On my Stan's rims, they measure about 40mm. As has been said already, you should see an increase in puncture protection by going to the GK. They make a slick version (same casing, but slick tread instead of small knob) but I would avoid it. I'm not convinced that the slick rolls faster on gravel, and you give up grip (climbing and cornering) over the small knob version.
With that all said, I've heard that the Schwalbe is a fast rolling tire for gravel. I haven't used them. I've heard people say that they don't have good traction and I've heard they aren't super durable, but I've never heard people say they are slow! If you're looking for pure speed, there may not be many options better. For the courses I race on, I value protection over pure speed, and the Gravelking seems to fit into a sweet-spot in terms of balance.
The only complaint I hear with the Gravelkings is that they fling rocks on all the riders behind you, hence the gravelfling/gravelsling knick-names. Other than riders not wanting to draft me, i've had nothing but good experiences with these tires in size 35c, 38c, and 43c.
Hi, Rob. We've actually met before. Possibly Gravel Worlds 2016, or maybe The Epic in MO. Anyway...
I've had a few sets of the SK40s. (Back before they changed the hot patch to "43".) I've also had a set of the SK35s. (Again, before the change to "38".) I never had an issue with the 40s. However, the 38s I had kept losing knobs.
I'm not sure if it's because there was some sort of issue with the brown sidewalls when they first came out or what. But, after much back & forth with Panaracer, sending pics of the missing knobs, etc., they refused to do anything about it and wouldn't acknowledge there was an issue with the tires. That was enough to make me not want to give them another shot. It's a shame since I never had any issue with my previous sets, but what can I say? I feel like I got screwed out of $80ish on defective tires and I hold a grudge. LOL
Steve
"If you ain't first, you're last." Reese Bobby Talladega Nights
