jackmott wrote:
Duncan74 wrote:
In fact reading between the words in the statement then they appear not to be attempting to calculate the true power, but use an algorithm to translate the raw readings into an estimated power value.
Not saying there is anything wrong with this every power meter on earth does that.
an SRM doesn't directly measure power, a fancy automotive dynanometer doesn't directly measure power. you can't.
you can measure how many volts are coming out of a strain gauge, which lets you estimate how far it bent, with which you can estimate how much a crank/pedal/hub spinder bent. you then use algorithms to estimate the torque
then you get some readings on how fast stuff is spinning around, and then you use that and the torque your estimated to estimate power.
in all cases you will have to account for various 'weird' situations.
Just added back in the bit from my original quote.
Ok, but what 'wierd' situations are you needing to account with hub or crank systems? And is standing to pedal really classed as 'wierd'?
I get that people want a system that allows them to use different length cranks between road and TT bikes. And if it was possible to add to a spin bike in a gym, then I could really see that as a plus as I tend to do a fair few spin classes over winter to mix it up. But there seems a lot of 'emperor's new clothes said about the pedal meters which doesn't always seem to be tempered with the disadvantages. Overall, people should choose the system that best matches their needs - strong where they need it most, weak where it's less of an issue.
