Jason N wrote:
I don't see this as replacing my current bike computer. There is no way I'm spending $400, for a product that doesn't currently solve a problem I have. .I don't think you meant literally replace your computer, but it couldn't do that under the best of circumstances since it still requires a specific model of Garmin computer to aggregate the sensor data and pipe it to the glasses presumably over bluetooth.
The biggest struggle with devices of this type is probably battery life, you can only strap so big of a battery to the side of your head before people will simply not tolerate the weight. Recon tried to compensate for this by giving you two batteries with the intention that you'd just hot swap it during a longer ride. Garmin's take appears to be based on offloading as much processing as they can to your existing head unit and keeping the display as lightweight (physically and from a SW perspective) as possible to maximize battery life.
This would also explain why it's limited in compatibility to their latest and generally most powerful head units as it needs to piggyback off of their processors and batteries to a certain extent.
