Greyhound wrote:
What are options for power meters besides the Stages Power meter with GRX? I like the Quarq D Zero that i use on my rode bike but its not compatible.
Any suggestion?
Thanks
David
I assume you want to keep the sub-compact gearing? If so, there are not a lot of crank-based options, yet, and none for 24mm Hollowtech bottom brackets that I'm aware if. If your bottom bracket shell supports 30mm axles, there's the FSA Powerbox Super Compact (48/32 or 46/30) which is a Power2Max derivative. Not sure what the chainline is with the Powerbox; if it's "standard road;" you might need a regular road FD. There's also the Rotor 2InPower DM which has 48/32 or 48/30 chain ring combos. That one definitely has "standard road" chainline.
