As you know, sports scientists are often confused by what ' threshold' means. They seem to keep changing what they mean, or can't agree with each other what they mean by threshold. I've just checked a few papers and text books and it seems blood lactate at MLSS is between 2 to 8 mmol.L. But many sports scientists seem to have taken 4 mmol.L to mean ' threshold'.
The article below sums up this confusion.
https://www.trainingpeaks.com/...d-lactate-threshold/ ""Many authors and coaches have been trying to answer these questions for a very long time. The first description of a blood lactate threshold dates back from 1930 and it was named by W Harding Owles, the “Owles Point”. In 1964 Waserman and Mcilroy proposed the term “anaerobic threshold” based on the belief that lactate accumulation was due to a lack of muscle oxygen availability and therefore anaerobic muscle metabolism was necessary for the continuation of muscle contraction. Mader and co-workers determined in 1976 that “anaerobic threshold” was reached at the blood lactate concentration of 4 mmol/L (milimol per liter) which was in 1981 named by Sjödin and Jacobs “Onset of Blood Lactate Accumulation” (OBLA) occurring at the blood lactate concentration of 4 mmol/L as well. Farrel and co-workers proposed in 1979 the term Onset of Plasma Lactate Accumulation (OPLA) which was the exercise intensity that elicited a blood lactate concentration of 1 mmol/L greater than baseline. Another term proposed in 1981 by LaFontaine and co-workers was the “Maximal Steady State” which in theory happens at a blood lactate concentration of 2.2 mmol/L. In 1983 Coyle and co-workers proposed the term “Lactate Threshold” which was a non-linear increase in blood lactate of at least 1 mmol/L. Another term, “Maximal Steady-State Workload” (MSSW) was proposed by Borch and co-workers in 1993 and was established at the fixed [La-] of 3 mmol/L. Veronique Billat in 2003 proposed the term Maximal Lactate Steady State (MLSS) as the exercise intensity at the one blood lactate can be sustainable.""
As to resting blood lactate. Many people are stressed all the time even at rest. Seeing as you are such an expert perhaps you should inform Wikipedia they are wrong in stating 0.8 mmol.L to 1.5mmol.L. as resting lactate.
Whichever way you look at it, MLSS is not a true steady state, Christ knows why sports scientists named it Maximal Lactate Steady State because a rise of up to 1mmol.L is a large percentage of any level between 2mmol.L and 8mmol.L. If you take the lower 2mmol.L it's 50% and at 8mmol.L it's still a rise of 12.5%.
Personally I think blood lactate testing is a waste of time when you have the ability to test power over set durations. Perhaps it had a use giving people heart rate zones back in the heart rate monitor fad days.
Andrew Coggan wrote:
Trev wrote:
Resting lactate is approx 1mmol.L. to 1.5mmol.L. When you reach the so called lactate threshold, which is disputed as it isn't there if you take enough measurements, it is claimed to be 4 mmol.L, and it continues to increase exponentially. So an increase of 1mmol.L over the last 20 minutes of a 30 minute MLSS test is on average 25%. To call an allowed increase of 25% in lactate ' steady state ' is a joke.
Never send a theologian to do an exercise physiologist's job.
Resting *blood* lactate is generally under 1 mmol/L. Only if your subjects are stressed, you measure plasma instead of blood, or your analyzer or sampling technique are biased will you routinely obtain a higher value.
A blood lactate concentration of 4 mmol/L would be OBLA, not lactate threshold.
Although a 1 mmol/L increase over time might seem large, it needs to be interpreted in the context of not only the starting value, but also sample-to-sample variation (which isn't insignificant, because unlike, e.g., glucose, lactate levels aren't regulated). More importantly, it needs to be recognized that that although lactate might drift up or down by that much over time during exercise exactly at MLSS, *the rate of increase is much greater at only a slightly higher intensity*.
IOW, that rate-of-change should be compared to what happens at slightly lower or higher intensities, not the static resting concentration. (you actually recognize this yourself, in alluding to exponential increases).
Regardless of the details above, the limitations of blood lactate testing, or any other physiological measurement, are why since my grad school days I have been pointing out to people that:
The best predictor of performance is performance itself.
