DarkSpeedWorks wrote:
Thanks for the link, but it looks like the volt 1700 is no longer available in the US, except on eBay for crazy prices.
What do you think of the brightness and effectiveness of the ampp 1100 (except the weight) ?
The 1100 is a very good light with a great beam pattern. Cateye's website lets you compare beam patterns side by side. It could work great as a daytime, daytime to dusk to night light. If you were to use it solely at night time on roads with traffic and little other ambient light, I still suggest having more total lumens. On rides started at night, I use the ampp 500 as a helmet mounted light. The 500 has a brighter spot, which is great for getting car traffic attention. The 1100 has a much wider, more spread out, no strong center spot, but a smooth usable light source for night rides. It has really nice optics. I should add all the ampp lights have side panels that allows the light to shine forward and can be seen on both sides. This is good for additional visibility of you from a car's point of view on side roads.
I have been doing night rides for over 10 years. I have a lot of lights from a lot of companies, niterider, light and motion, lezyne, dinotte, serfas, even high end German lupine lights, and I really like the cateye ampp lights when considering: reliability, clean mounting (I use a gopro mount), easy to swap different cateye lights between the gopro mount, lightweight, battery run time, beam shape, and very usable light patterns (so many lights have overkill light patterns of which I think many are useless). Also, I don't need bluetooth or remote switches. My lupines have these and I don't use those features. I like it simple.
I recently tried the Giant recon hl 1800 to potentially replace my volt 1700. The Giant was a little lighter, but inferior, in my opinion to the volt as it related to the light patterns and also battery run time was shorter than advertised. I ended up returning it.
Good luck in your decision!
