echappist wrote:
One of my bikes (a S&S-retrofitted titanium bike) doesn't have internal routing. Yes, I could have it further retrofitted to run wires through at least the down tube, but that would represent a major PITA, though not nearly as expensive as getting Sram Etap.
I could, in the alternative, run Di2 externally for the time being. It's a bit ugly, but at least it would work.
So here's my question, anyone with "insider" knowledge as to when Shimano will go wireless as well?
I have a friend that is very close to a pro tour team. Supposedly Shimano asked pro tour teams a couple years back if there was an interest in a wireless Di2 version. The Mechanics provided Shimano feedback that there was no interest in wireless, since all (or nearly all ) high end frames come designed for internal Di2, and Di2, just works really well and works really reliably. Maybe their answer is different today, but you don’t see many teams on etap....
My partner and I were earlier adopters to etap, and have well north of a combined 20,000 miles on
. We previously had mechanical Dura Ace. Our bikes, like yours, were not built for Di2 (older pre Di2 frames) and we wanted to go electronic (replacing our internal cables was a PITA). Etap, has lots of niggles: randomly unpairing (and no shifting until you re-pair), front derailleur alignment periodically going out of alignment, ghost front derailleur shifting (going quickly from high low high), battery tabs cracking, and I know of many that have front derailleur chain drop issues. I have a good friend, that after sram warrantied his rear etap derailleur for the 3rd time for failing during a ride, he gave up and went back to Di2. He was a 10 speed Di2 user previously... Another friend, has also had rear derailleur failures, and batteries cracking, as well.
It’s definitely not a set and forget system, nor as robust as Di2. Maybe their new system is better?
I’ve since, replaced my SRAM red crank, brake set, chain, and cassette with Dura Ace and its quieter and shifts better. Now if only Shimano would make a wireless version....
I also, thought about paying for retrofitting my frame to take wires for Di2, but I had worn out my prior Dura Ace Parts, so going wireless helped take care of two items: new group set and no internal retrofit needed.
