I need some help in deciding what size IA10 frame to buy. I'm stuck between two sizes: 48cm and 51cm.
Went to Pedro to get a sizing fit, and these are the numbers:
Shoulder width: 38
Crotch/inseam: 820
Trunk(measured from the pubic bone to the jugular notch/clavicle notch): 530
Arm: 634
Forearm: 634
Femur shaft: 522
Sit Bone measurements: 143
RETUL MEASUREMENTS ROAD/TT
Saddle height: 73 (bottom to the top/center of saddle)
Saddle height 2nd location: 89 (bottom of the crank-6 o’clock to the top/center of saddle)
Suggested crank length: 165
Seat Tube angle: 79.0 degrees
Head Tube angle: 71.5 degrees
Effective Top Tube : 48.6
Tip of saddle to center of handle bars or base bars(T.T.): 51.0
Tip of saddle to hoods or brakes of base bars(T.T.): 69.0
Stem Length: 90
Stem Angle: -6
Steer tube spacer: 20
Seat angle: -5
Name of saddle: ISM pn 2.1
Hoods/base bars degree angle: 11
DROP bars and height of saddle: 14
Aerobars bars degree angle: 7
Aero Bars pad height and saddle height: 90
Reach: 389
Stack: 501Apparently I'm at the top end of the 48cm frame and at the lower end of the 51cm frame. Felt Support voted for 48cm based on my height and inseam measurements alone, though Pedro said either frame could work (both would need some adjustment). I'm not sure about the implications of going for one or the other. I would greatly appreciate any insight for swinging the vote one way or the other!
Quote:
Height: 5’5 / 1665 Shoulder width: 38
Crotch/inseam: 820
Arm: 634
Forearm: 634
Femur shaft: 522
Stem Length: 90
Stem Angle: -6
Seat angle: -5
Reach: 389
Stack: 501
