JasoninHalifax wrote:
GreenPlease wrote:
I’ll believe it when I see it. Zipp’s 454 and 858 have pretty wild shapes but they made that work with rim brakes. Knight’s old rim shape already traded speed for stability... again, in rim brake format. Unless they add turbulators to the surface of the rim, I’m not buying their argument.
except they're talking about not trading speed for stability, but getting both by using a wider rim that will blend with a wider tyre, which can then be run at lower pressures. Better rolling resistance, better cornering, better compliance on rougher roads, and aerodynamics to boot.
That's what they're saying, anyway, but it is true that the disc removes a significant constraint on rim shape.
The "better rolling resistance" goes away when you adjust tire pressure for casing tension (which you should, otherwise you actually get worse compliance). Flo's first go with their casing tension study showed as much (and basic physics predicts that's the outcome). You only get "better" compliance if you drop air pressure below a casing tension equivalent air pressure. Wider tires
let you do this because you have more volume and therefore more margin before you get a rim strike. Wider tires do not automatically give you more compliance. Try pumping up a 2.3" mountain bike tire to 60 psi (which would be "low" for a road bike tire) and see how it rides. Actually.... don't. The tire might blow off the rim. Because of casing tension.
