Re: Disc brakes: Centerlock vs 6 bolt [culpritbicycles] [ In reply to ]
culpritbicycles wrote:
Have you used adaptors for 6 bolt to centerlock?
I've seen these adapters, but they all seem to be for centerlock to 6 bolt. Are you saying there is a 6 bolt to centerlock adapter as well? If so, do you have a link to them?
I currently have a 6-bolt setup but would like the option to run centerlock if possible, but haven't seen that type of adapter available.
Re: Disc brakes: Centerlock vs 6 bolt [JasonGeorge] [ In reply to ]
Centerlock all the way.
BUT if you need to do 6-bolt, then a little battery powered driver with a T25 is really nice to have.
I have a few of these kicking around.
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
The above poster is a physiologist employed FastTalkLabs. However, statements are not made on behalf of nor reflective of FastTalkLabs in any manner... unless they're good, then they count. http://www.FastTalkLabs.com
Re: Disc brakes: Centerlock vs 6 bolt [TRIspud] [ In reply to ]
"I currently have a 6-bolt setup but would like the option to run centerlock if possible, but haven't seen that type of adapter available"
That isn't possible.
sorry meant to use 6 bolt rotors on a center lock hub. there is nothing going the other direction
While we are on the subject of rotors, let me ask another question, this time concerning size. Keeping in mind that this is for a TT/tri bike (and I weight 147 lbs / 67 kg), I suppose that the argument in favor of 140mm is weight savings and in favor of 160mm is better heat dissipation. Is there anything else to consider?
Buy Shimano IceTech rotors in 160mm.
