Converting 2021 Tarmac Pro to Tri bike
Thoughts appreciated!
Love riding my Tarmac. Considering using it for IMC. I can attach Venge aerobars and a 0mm setback seatpost. All in I'm looking at Cad $1,000-$1,500 for that setup vs CAD$6-8K for a new tri bike. How far off do you think the tarmac conversion is? i.e., Am I getting 90% of what I'd get out of dedicated tri bike?
Thanks!
Re: Converting 2021 Tarmac Pro to Tri bike [mckinley99] [ In reply to ]
I just set a guy up yesterday on a 1st gen tarms with super old PD aerobars. It endedup surprisingly well. Zero setback post saw the ISM saddle about 80mm behind the bottom bracket. Not exactly modern tri but not too bad for a 6'3" rider. Other than the aomewhat slack position, the low front end, ability to swap stems, and decently adjustabler aerobars saved the day. You get most of the gain of a tri bike from a properly invested in* and set up road bike.
*Adjustable low stack aerobars, an aerobar friendly saddle, maybe a forwarding seatpost, probably a shorter crank.
Re: Converting 2021 Tarmac Pro to Tri bike [FindinFreestyle] [ In reply to ]
Profile Design still makes a seatpost with negative setback so you could cut down on that 80 mm.
https://profile-design.com/collections/seatposts
