ericlambi wrote:
irondave wrote:
I have been taking Youtheory collagen for about 2 years now. Get it at Costco. Can't say I notice any difference, but I know someone that did have bone mass analyzed before and then after taking it for a while and the density had increased.
Is increased bone density an expected outcome from collagen supplementation? I just had a bone density scan as a follow-up to a hip stress fracture. My density was below average, seems it needs improvement.
Eric, do you know where you showed below average bone density??
Do you run much?
The reasons being:
1. If you drop weight bearing on an affected area you will quickly lose bone density around the fracture site. So did you have an isolated decrease in bone density or widespread decrease?
2. You often need the "trauma/impact" of weight bearing exercise like running to assist with bone density. Things like cycling itself won't do much for increasing bone density.
This is coming from both an MD and someone who went through a nasty hip stress fracture, and had nearly every investigation under the sun to try and figure out why.
