johnnybefit wrote:
I am interested in this too. I wear the Glycerin right now and have for a few years. I tried the Bondi B and found that the way the shoe last locked in my feet gave me all kinds of trouble with foot pain. Once I switched back to the Glycerins I was fine. I am hopeful that Hoka will release a truly neutral shoe without any guidance support - a shoe just like the Glycerin but with the Hoka cushioning.
Thanks, John
Hey John. The Hokas you tried are technically neutral, they don't have any "active" guidance or support, I always considered it more of a passive support (wide base, flat midfoot platform, etc). However, those are... kinda what makes a Hoka a Hoka, they're intentionally different shoes. Given how soft they make their cushioning, if they were to make the shoe fir narrower, or get rid of some of the design components that Hokas have in common with each other, you would end up with a dramatically different shoe. If you took the glycerin last and built a Hoka around it, you might still end up with the foot pain. They were just designed to be very different.
Might I suggest you try out something from Adidas' Boost lineup? The cushioning isn't quite as soft as the Hoka, but the difference in cush is noticeable compared to a Glycerin. Plus, they're cut on a little bit more traditional last. Might be a good option for you.
