Do any of you use breathing to measure how fast you are going within the miles themselves, you are running?
Unless you are out on a track, or running on paths with marked distances and measured landmarks, how in the world, do you know how fast you are going within the mile itself; obvisouly you are going to exactly know the time of the mile you just ran, when next mile marker ends.
Let's say you want to run 7:15 per mile for the first 10 miles. You are only going to know the result of how you are going in that mile, after each mile, unless you have the path market out and measured, or are strapped down with a GPS watch. But let's say you don't know. You are on mile 6, and, ahhh, ohhh, you just ran an 8:10, for that mile. Now you have to hurry up.
It seems to me there would be a value of knowing your pace, accurately, within each mile you are running.
Of course, for many of you, you will say, "I use a heart rate monitor," or "I use GPS, for that." But, for people who use heart rate monitors for this, I don't see how that helps, unless you have some solid data on how your BPMs work for you at different temperatures. For me, if it's 95 degrees outside, I'm going to get a different reading than I would if it were 62 degrees. To keep a 7 minute mile at 75 degrees, my BPMs might be 162, when its 95, it might be 182? Who knows?
Do some of you count your strides per breath? Does that work. Like, if I take five strides per breath, I'm running a 7 minute mile approximately. 4 strides, 8-9 minutes, 2 strides per breath, 12 minutes, and so on.
