Bike position critique - excessive quad soreness
I’ve been on a bit of a journey with my bike position the last couple months. Things were mostly OK until mid-October until too narrow pads made my shoulders and neck sore, and I compensated with an anterior pelvic tilt, which in turn led to back tightness (and eventual strain) and increased quad pain. I figured out the pelvic tilt issue - in the video below I’m engaging my core strongly and feel like I’m in a slight posterior pelvic tilt or at least neutral, which really helps my back. I thought my quads would be better by now, but I continue to have excessive soreness and tightness, particularly closer to the knees, even as my volume and intensity are much reduced. Maybe I just need time, now that the anterior tilt is gone, for things to settle down. Thanks in advance for anyone taking the time to critique my position!
https://youtube.com/...6VjDik?feature=share
Note: I tried to embed the video in the post using the YouTube url but I’m just getting the question mark error symbol. What am I doing wrong?
Re: Bike position critique - excessive quad soreness [Greg17815] [ In reply to ]
It looks to me that you seem cramped up front. You appear to be sitting further back on your saddle and if I was you I would personally slide more forward on the saddle and want to extend my reach.
Do you like your current extensions? Your hand position doesn't look comfortable-or you don't look comfortable in that position with your hands.
If you haven't been to see a fitter yet, I would suggest doing so-it will likely take any of the guesswork out of it. Especially if they start you from scratch and put you into a fit that works for you then transfer that to your bike.
caveat - I'm not a professional bike fitter, just a nerd
you look so crammed. bike may be too small for you. that shiv geometry was very short.
elbows appear to be well inside the pads, reach looks short
hips rotated back
go longer, rotate your hips forward, get elbows closer to being on pads
narrow is aero, comfortable and able to hold it is also aero
you just look SO uncomfortable
Merge Multisport Founder & Head Coach
USAT Level 2 - Short & Long Course
Ironman Certified
Brevard, NC
I agree with the others. You look cramped and uncomfortable. Your front end needs to be extended or adjusted to let you settle in.
Re: Bike position critique - excessive quad soreness [MergeMultisport] [ In reply to ]
Thanks - I'm actually rotated forward as far as anatomically possible without going into an anterior pelvic tilt. If I tilt the saddle down more (currently it's a slight drop) I start to fall forward and my quads get more overloaded. As far as moving my elbows further forward, it doesn't feel comfortable when I do that, and I can't get as low with my shoulders and head. But there is plenty more reach available in the Shiv. The pads are only in one of the middle positions.
Since my back strain I generally have not felt comfortable on the bike. But before that, pretty comfortable.
Re: [ In reply to ]
Not an expert either and I feel like your elbow pads can move forward slightly to open up your upper body? Changing the frame or bike is a big deal and too much hassle, so I wouldn’t go that far since you used to feel comfortable before.
why are you trying to avoid an anterior pelvic tilt? that's literally the entire goal.
Your thoughts are outdated.
Long isn’t comfortable because you aren’t used to it
Low is not better. Narrow is. Go look at Sam long on the bike. He barely has drop from his saddle to pads
On a Tri bike the pelvis NEEDs to rotate forward. That’s kind of the vibe. You need to adjust your mindset as well as your position.
Ironman Certified
Brevard, NC
Re: Bike position critique - excessive quad soreness [jkhayc] [ In reply to ]
Exactly. He needs to understand HOW to sit on Tri bike
Ironman Certified
Brevard, NC
I’m not super special but look at my pelvis.
https://youtube.com/...?si=wDQviRfjln7Qj2Bp
Ironman Certified
Brevard, NC
People get arrested for saying that. :-)
Favorite Gear: Dimond | Cadex | Desoto Sport | Hoka One One
Re: Bike position critique - excessive quad soreness [The GMAN] [ In reply to ]
Shit. I meant to link my OF
Ironman Certified
Brevard, NC
I think others have said this, but looks like a tri specific saddle, which means you want to rotate your hips forward they are built that way(ISM saddle)? Rotating forward/anterior tilt is the point of the saddle and TT position. As far as anything else, I can't comment on. You want anterior tilt.
You don't know how to sit on that saddle properly.
Are you confusing pelvic rotation and tilt? Because I just can’t believe that an anterior pelvic tilt is good for cycling or good for anything really. It disengages the core, disengages glutes and hamstrings. What am I missing here?
Re: Bike position critique - excessive quad soreness [lonniecdams] [ In reply to ]
Again, I think we are talking around two different things. Anterior rotation (rotating forward) is definitely a good thing. And I am rotated as far forward as anatomy will allow. Pelvic tilt is a totally different thing. Everything that I read (and my own experiences) discourages anterior pelvic tilt. It shuts off the core, glutes, and hamstrings.
You’re missing an understanding of how to sit on a tri bike. I
Ironman Certified
Brevard, NC
Asks for advice
Is given good advice by multiple people
Ignores it all because he knows better.
Best of luck dude
Ironman Certified
Brevard, NC
That could be, I must not be understanding. Professional bike fit might be best solution to your questions.
Pelvis compared to torso you’re in posterior pelvic tilt/rotation. Same damn thing. You’re not even neutral.
Ironman Certified
Brevard, NC
When I do an anterior tilt on the bike, my back hurts (more), my asymmetries become more pronounced, and my quads light up. I do appreciate your advice, and while you very well may be generally correct in your assessment, there’s something else/more going on that I don’t have a handle on. Definitely due for a professional bike fitting - it’s been two years and there’s been a lot of water under the bridge since then.
If you can stand up straight without pain you can sit on the bike better.
You probably don’t have room to rotate forward with your hips because that will snake you need more reach in your cockpit
Go longer, raise the bars for a bit, and rotate your hips
Or I can recommend a great fitter in Greenville SC who will charge you to tell you this same stuff 😉
Ironman Certified
Brevard, NC
Thanks - I’ll check back in after a few weeks with an update. Apologies for being stubborn to good advice - it’s a feature, not a bug 😉
What is the difference between pelvic rotation and pelvic tilt?
Long story short, you have way, way too little reach on your bike and you’re probably too low as well. But those things aren’t mutually exclusive.
When you try to rotate your hips forward, are you disengaging your core and hyper extending your back? When I’ve done this, it puts a lot of strain on my back. So try to rotate your hips slightly less and keep your core engaged. (Suck your belly button in). When you do this, you should feel your glutes, hamstrings, and quads all working together as a system.
blog
