Raw Vegan wrote:
I use the Roka F2's and they've been flawless. I did need to change the nose bridge piece at time of purchase to a smaller bridge.
I used Aquasphere and Tyr before and they leaked really bad on me. Took years to find goggles that didn't leak.
Other tips are to slightly push on the goggle to suction out the air, tuck your chin on push offs and place the straps closer to the crown of your head and not behind the ears.
Good luck. This problem is awful from someone who struggled for a long time with it. I tried these tips this morning and it actually helped quite a bit. I only had to stop once to adjust the Roka F2's during my 1,750y swim. Since there are quite a few good cheaper recommendations, I think I'll pick a few more pairs up and continue experimenting.
Duncan74 wrote:
I've driven many a swim shop crazy attempting to get something to fit. Clearly it's my fault for having an 'odd' face, and once I finally found a really good shop that could explain the specific issues it save a whole lot of trial and error. Basically I've got quite narrow eye sockets that means the in socket dont seal on the outside, combined with a pronounced neanderthal ledge brow that conflict with goggles that try to go 'over'.
I new use the speedo futuro, which is a nominally a women's goggle, but really means the proportions are scaled to fit my grotesquely distorted features smeared over the head of a 6'4" bloke. And they have been great for the last 2 years, getting through about 5 pairs (3 of which when the seal went between lens and rubber gasket, although that was after plenty of use and I take zero care of them.)
So that's another thing to try if you have a narrow face. Note that although female badged, there is a non pink colour (orange) that I don't find offensive. Noting that I wear them when in swimwear / rubber suit then in no universe is it going to be the colour of goggles that results in someone making mocking comments at me.
It seems we have similar shaped faces. I also have a very narrow face with a fairly pronounced nose. I like to say it's aerodynamic and has a good intake system.
It seems like many are recommending Magic5 goggles, which are pretty pricey, but I suppose I could try out a few of the cheaper options first, including Swedes and the TYR Nest Pro's. Thanks for all the great recommendations and suggestions.
