grumpier.mike wrote:
Well I still built a 1X 12sp Shimano bike because I am not a fan of the small chainrings and the flat top chain.
One topic that isn’t clear in any documentation is the mix of brake calipers and levers. I did the new 12speed Ultegra calipers with the 11sp DuraAce levers and it seems to be working fine. I am not sure if I am getting the extra 12sp pad clearance, but things seem to work as well or better than my Ultegra 11 sp road bike.
Definitely! Yep! Keep in mind that 10% of 'almost nothing' is still very little though :)
I have also run my crank with both an 11sp and12sp setups and my Wattshop narrow-wide chainring has worked with both. So while Shimano would like everyone to believe that there is no compatibility between 11 and 12 sp groups, they seem to play together reasonably well.
Yeah.. I have used my 11-speed front ring with my 12-speed Di2 no problem for about a month.
I did find it to be noisier than my 12-speed ring, but maybe my 11-speed ring is just worn. I have only tested one, so can't tell for sure. It shifts just fine though (2x on my road bike).
On compatibility... I can see why Shimano say the 11-speed crankset isn't compatible... See the left image below. There is very little clearance between the 11-speed drive side crank arm and the front derailleur. I've even pushed the crankset out 1mm using a 'spindle washer' :).
The 12-speed crankset (right image) has a much better gap between FD and crank arm.
BetterShifting.com - Di2 help and guides|
BetterShifting Instagram |
Terry's Instagram
