of course, there are several factors to consider with air temperature.
There's the difference in air density that will have some effect. There will also be the impact of humidity. higher the humidity, the less your sweat evaporates and you stay hotter, for the same temperature.
the big thing I notice on warm/hot days is the energy I lose saying "FK it's hot today. FK I hate the heat. FK it's miserable today. FK, I still have to run in this crap.....". I find that I simply can't push myself in the heat, and even if I do grit my teeth and man up.
Given your increased wattage output, you probably do better in the heat (less swearing at least) than I do. Your difference will be due to other factors.
TriDork
"Happiness is a myth. All you can hope for is to get laid once in a while, drunk once in a while and to eat chocolate every day"
TriDork
