I was also part of the Slowtwitch team, and was quite honored to be included in this cool review. Pairing the CORE was relatively easy through Garmin ConnectIQ, and I got it set up as a new data field on my watch and bike computer. The device slides onto a HR strap with a couple of clips or can also be worn with included patches. I've only used it on my HR monitor strap. Once it's on, you don't notice it's there while working out.
I live outside of Boston, and while we don't get the sweltering heat of other parts of the country, the humidity is often very high. My first race of the season was Eagleman, and I was interested to see what my internal body temp was during the race. I got the CORE a couple of weeks prior to the race, so I was able to test it out a bit, but I didn't do the heat ramp test prior to the race. One thing that the CORE validated for me was that once your core temp is elevated, it is pretty hard to reduce quickly. It's not like HR, where easy spinning or coasting down a hill drastically lowers HR. Your core temp may go down .1 degrees F on a 2-3 minute downhill without pedaling. Having this metric and getting to know your temp zones is definitely great for racing. I think many of us have gone past that point of no return, sometimes without realizing it, and the internal temp gets too high to do much of anything. The CORE allows you to monitor your temp and back off a bit to try and stabilize your internal temp on hot days.
As Lars mentioned, the heat ramp test isn't nearly as draining as an FTP test. You essentially eliminate any cooling and ride inside. I wore winter attire - tights, socks, jacket, hat & gloves. The basic idea is that once you hit 38 degrees C you try to hold your HR constant for a period of time. Over time, your power begins to drop as the heat builds up, and eventually you reaching a stopping point. For me, I got to just over 39 degrees C or around 103 degrees F. There is no specified time limit like 20 minutes in an FTP test - more of you know when you are cooked (kind of literally). Then you can go back and look at the data to find your heat training zone for acclimation.
Getting back to the race at Eagleman, unfortunately I crashed coming out of T1 - completely my own error. At that point my core temp was right around 103 degrees. As a result of the crash, I smashed my lower left leg and was unsure of how the rest of the race would go. My power was 30-40 watts lower than planned because of the crash, and this led to my temp dropping over the course of the bike. Down to around 101.8 at the end of the bike. The run was a hobble due to the crash and my core temp pretty much stayed constant a bit under 102. Race conditions were perfect for Eagleman, with cooler temps and lower humidity than normal. I wish I could have seen how I could have gone without the crash, but it was good to see that backing off a bit does get the internal temp down to a lower level.
I've been using CORE on pretty much every run and ride since Eagleman, and I really feel that being able to monitor internal temp is extremely valuable for any training or racing in hot/humid conditions. Having another metric that you can get to track over time to pair with HR and power allows me to begin noticing trends. As I've built back into the training and am getting a bit more heat acclimated I'm noticing that the CORE is giving me slightly lower internal temps at running paces and power compared to a month ago. I've also noticed that even with fans inside, the body temp gets elevated more rapidly than outside. This is kind of a no brainer, but being able to track and monitor the internal temp can help make indoor training even better.
I'm racing in St. George in September, and I definitely plan to do several of the heat acclimation sessions. The gym I belonged to that had a sauna closed during the pandemic, so that isn't an option. I'm happy to try answering any specific questions others have.
Blog:
http://262toboylstonstreet.blogspot.com/ https://twitter.com/NateThomasTri Coaching:
https://bybtricoaching.com/ - accepting athletes for 2023
