In Reply To:
Quote:
Two words to disprove this CHRIS LIETO I disagree with that. Assuming the info here is correct:
http://www.examiner.com/...-world-championships, Leito biked at a 95 cadence and Alexander was at 82. Leito blew up on the run and was walking about the time Alexander ran past him. There's no such thing as a good bike split without a good run to back it up.
I'm not saying Lieto blew up on the run because of his cadence, but the difference in Lieto and Alexander's cadence and run splits at Kona would support a slower cadence being beneficial for running off the bike.
Here's a link to a study that supports a low cadence helping the run:
http://www.ncbi.nlm.nih.gov/pubmed/15849289 I've experimented with cadence in my training and found that a slower cadence helps me run better (I train with power and this is assuming that the slower cadence is coupled with low pedal force so my power falls primarily into quadrant 3). That may not be the case for everyone, but it's worth testing out.
This is from 2008, but it looks like Alexander's cadence is at least 80 (there are a few 20-30 second clips around 2 minutes in). Granted this but a few moments in time, but that seems to be the methodology used in the above link.
http://www.youtube.com/...&feature=related Also; I would consider "grinding it out" to mean that you increase pedal force at lower cadence to maintain power. I thought that was the point of debate; whether higher or lower cadence at a given wattage was more effective.
