2023 VEL 50 RL CARBON TUBELESS Disc Wheelset - Sram XDR
VEL 50 RL CARBON TUBELESS DISC WHEELSET
Brand new wheelset- still in box...opened only for pictures
$700 plus shipping
Review- Review: Vel 50 RL Carbon Tubeless Disc Wheelset | road.cc
Vel’s hand built 50 RL Carbon Tubeless Disc Brake Wheelset is both fast and efficient, making them a great upgrade from stock wheels. With an internal width of over 20mm they work perfectly with wider, modern tires, providing good support for the sidewalls and allowing lower pressures to be run for more comfort and grip. Their aerodynamic shape cuts through the wind to reduce drag without being a handful in crosswinds whilst the straight pull Pillar Wing spokes ensure accurate steering and good power transfer.
The Vel RE aluminum hubs house sealed bearings for smooth running and longevity, with Center Lock disc fitments providing safe, secure disc rotor mounting. The rear hub uses a 102-tooth engagement ring with six pawls for super-fast engagement, so the instant the power is applied the bike will accelerate. The rims come with tubeless tape already applied and as tubeless valves are also supplied, the conversion to using these tubeless-ready tires is a simple process. These rims can also be used with a traditional clincher tire and inner tube if preferred.
FEATURES
Clincher / tubeless-ready tire compatible
Double wrapped with tubeless rim tape
Wheel Size: 700c
Rim: Toray 24/30T carbon
Rim ERD (Effective Rim Diameter): 539mm
Rim Depth: 50mm
Internal Rim Width: 20.3mm
External Rim Width: 27.5mm
Spokes: Pillar Wing PSR21 straight pull, 14g, two-cross lacing
Spoke Count: Front - 24 / Rear - 24
Hubs: Vel RE Rapid Engagement, AL6061 CNC machined shell, sealed bearings, 102T engagement ring with six pawls
Bearings: Front 6902 x 2, rear 17287 x2, 6902 x 1, 6903 x1
Disc Standard: Center Lock
Front Axle: 12x100mm
Rear Axle: 12x142mm
Recommended Tyre Size: 25-34mm
Maximum tire pressure: 120psi
Manufacturer Claimed Weight: Front - 735 grams / Rear - 875 grams / Wheelset - 1,610 grams
Compatibility: SRAM XDR
Includes: Spare spokes and tubeless valves
Maximum system weight: 110kg
