sorry you are feeling crappy p2k,
i have tried everything for colds, from conventional medicine to naturopathic approaches, and have found that the single best remedy for me is also the cheapest and most readily available thing around: garlic.
take 2-3 cloves (a clove is a sub-section of a head of garlic...i had a student once who thought i meant 'take 2-3 heads' and ended up feeling a bit off :)), chop them into easily swallowable chunks, and just swallow them down with a lot of water. do it just before bed, and you are less likely to horrify your partner/spouse/dog. make sure you have a bit of food in your stomach. garlic is a really powerful antiviral and antimicrobial, and seems to wreak havoc on the rhinoviruses that cause colds. make sure you use fresh garlic, not garlic pills or capsules or other forms of expensive "odor free" stuff. the fresh bulbs are key.
if your throat is hurting, zinc lozenges (with zinc acetate) seem to work really well for many people.
i hope you feel better soon--toadpalmer
http:www.kenyawilds.com/faculty.html
http://www.kenyawilds.com/faculty.html
