That's really cool and makes a lot of sense. I doubt Classified has the economy of scale, I'd assume their production run is on the order of magnitude of 1,000 hubs. What order of magnitude would the cost be to refine 1000 of these little hubs? Closer to $1 per hub or $100 per hub? These hubs are selling for well over $1,000 each, I wouldn't think that adding $10 in cost and bumping up the price to $1,020 would be big market loss, but I'm not into that side too much.
5k miles is a lot more than I thought you'd get out of them. Thinking about it more you'd really only incur substantial wear when using the reduced gear, locked out should be effectively zero wear.
This still leaves the question - All of this work to get to 99% efficiency, which makes the hub comparable to a 2x system in the most extreme cross-chained scenarios and 1% worse than a 2x in normal scenarios. I'm open to ideas and riding what's fastest, just having trouble seeing how the numbers point to Classified's system.
