I have a 2012 Cervelo P3 Tri-bike, and am looking for 60mm 3T Aura-Pro Risers. Any suggestions as to where I can find them? Thanks.
Re: 3T Aura-Pro Risers [tmfehringer]
Wow, I also have a 2012 P3 and would love to find the risers, too.
Re: 3T Aura-Pro Risers [candyman]
I am told these are compatible, but I'm hesitant to pull the trigger and purchase without verification from someone more experienced than I. None of this would be a problem if I were as flexible as I used to be!
https://www.speedmetrics.com.br/...ts/straight-spacers/
tmfehringer wrote:
I have a 2012 Cervelo P3 Tri-bike, and am looking for 60mm 3T Aura-Pro Risers. Any suggestions as to where I can find them? Thanks.They were as rare as Hen's teeth 2 years ago, and I'm sure the situation hasn't improved. Fibre-lyte make compatible spacers from carbon fibre though- which I think you should be able to stack up, perhaps with a cross brace at the top for stability. https://www.fibre-lyte.co.uk/...ycles_timetrial.html. Their standard is 6mm, but I imagine they will do a 10mm if you ask.
tim_sleepless: Apr 24, 24 2:55
Re: 3T Aura-Pro Risers [tim_sleepless]
Thank you, Tim. I sent them an email this morning making an inquiry as to whether they are custom-making 60 mm risers and whether they recommend a cross-brace. Sure appreciate your referral. Thanks.
tmfehringer wrote:
Thank you, Tim. I sent them an email this morning making an inquiry as to whether they are custom-making 60 mm risers and whether they recommend a cross-brace. Sure appreciate your referral. Thanks.No problem. I doubt if they'll do 60mm, as they'll cut the risers from a CF sheet, but they should able to supply multiple 10mm ones.
