Is Zwift still possible with a Computrainer?
Is anyone using Zwift with a Computrainer? Mine does not seem compatible anymore. It’s so sad.
Thanks.
"It's nice to be great, but far greater to be nice"
Re: Is Zwift still possible with a Computrainer? [yoe400800] [ In reply to ]
I used mine last week.
A friend of mine used his yesterday.
Thanks.
possibly this can be helpful
Thanks.
Also, check out PerfPro’s CT Smart application, which will enable you to broadcast the CT as a more modern ANT+ trainer.
Thanks.
I had an issue a month ago (or so) called Zwift. They told me they had stopped supporting Computrainer and the upgrade I had just done may have caused Zwift to not connect anymore and you can't "undo" upgrades. I ended up buying the zwift hub and their "click to shift" which has made it very quiet. So although I miss the Computrainer, the new set-up is nice.
I've been using a computrainer for years now and mine still works with Zwift. Mine was purchased in 2014. For the past year the calibration doesn't really work anymore. And I feel like the watts are off but that is not due to Zwift. It's just my computrainer is almost 10 years old. I don't know how old your computrainer is but if it's 10 years old or newer, it should work with Zwift. Oddly enough I have the Kickr Rollr being delivered tomorrow. I need a different ride experience for my knees and lower back. I already sent back a Wahoo Kickr as it felt like riding in sand and irritated my knees quite badly. (you do need a power meter for the Rollr to work with Zwift).
ETA - just read B.Mcmaster's post. So I haven't upgraded my Zwift and I think I hit the "later" option for the latest update. And I haven't been on my trainer in a week due to tweaking my lower back. My Rollr is arriving just in the nick of time as my back is feeling better and I should be on my bike this weekend.
Death is easy....peaceful. Life is harder.
Re: Is Zwift still possible with a Computrainer? [Triingtotrain] [ In reply to ]
I bought mine second hand in 2012 from Carmichael Training.
It was probably 6 years old then.
I use my powermeter for the power source so I never have to calibrate the CT.
Thanks everyone.
I must have upgraded some time. When I’m on the pairing screen Zwift recognizes my CT for about 3 seconds, then drops it.
Maybe I’ll try the PerfPro solution.
yoe400800 wrote:
Thanks everyone.
This is another issue they are having even with some of their hubs. After a few calls, I was told to pair through my phone and it fixed the issue. But I can't pair through bluetooth at the moment.
