Canyon Speedmax size question
Hello,
If I use the canyon size tool: 183cm height (72 inches) and 89cm inseem (35 inches) -> the tool gives me size M.
https://ibb.co/VpWtRFz
Now this is out of stock. Large is not.
I've been over to a Canyon Service point and I should be able to fit a large with no problem.
My saddle heigth should be 79cm. Lowest possible is 77.5cm for a large frame.
It is not much margin but more then enough.
https://ibb.co/kM92nCp
Benefit here is that U have a lower seatpost, less stack height, so better aerodynamica. Based on this article here on slowtwitch from 2010. Maybe to old of an article??? : https://www.slowtwitch.com/...ike_sizes__1173.html
The reach is also fine. Extra benefit is that my saddle can be very much forward and that I am good in front of my center bottom bracket. So I can put more power on the pedals. Right?
What do you think of my reasoning here, my thinking... What do you think, suggest,... ? Correct me when I'm wrong pls.
Regards,
DVR
Re: Canyon Speedmax size question [Roflpain] [ In reply to ]
Check out the link below. Post your pad X, Y along with your height and inseam and Ian will be able to provide some guidance on sizing.
Speedmax fit
