PushPlay wrote:
I've used Athletica for two years now and never experienced that the set intervals and total workout time don't match. Maybe you are not reading the workout correctly? Also, you need to go to your Garmin and make sure your Garmin settings are correct and match the zones with Athletica. Athletica can't push the zones to your watch. So if you have done the test week with Athletica and got your training intensity zones adjusted, then you still need to go to settings on Garmin and change the zones there. Otherwise you will get those discrepancies with Garmin. Hope this helps :D
The first issue seems to be somewhat common recently as it popped up on there forum.
Thank you for letting me know about Garmin though. I definitely need to do that!
