Warbird wrote:
MrTri123 wrote:
I have gone with 80 lbs which it seems HED recommends
Silca shows 100
Or maybe I did the calculations wrong?
25mm GP 5000 Latex tubes 225lbs bike with rider HED disc rear wheel 60 from clinchers
I'm also ~225lbs total weight. Is 25mm the actual width of your tires on those rims, or are you just going off the stated size?
Silca calculator wrote:
Measured width does not equate to the number printed on the sidewall; rather, it refers to the width of the tire when it is fully installed and inflated on the rim. Even dealing with this stuff every day, it can be hard keeping it straight as we continue to call the tires by their casing numbers. That said, we have seen 23mm GP4000SII on a 21.5mm inner bead measure at 28.9mm wide, so would be 29mm in this calculator.
I just looked at the HED website and it say
75 lbs PSI for me
Maybe the chart is for tubeless?
https://hedcycling.com/...riant=45053395697954 On my tri bike, 23mm GP4Ks measured 26mm on FLO 60 rims. I testing was 5psi increments, my results were 95psi (bike path)/90psi (road) was the fastest, Silca said 95.5psi (new pavement) and 90.5psi (worn pavement/some cracks). 25mm GP4Ks on the same wheels measured 29mm, Silca says 80.5psi/76.5psi while my testing got 80/75psi. So I feel pretty comfortable going with Silca's results...
Thank you for your post
I just measured with calipers
You are correct they are not 25
Actual width is 26.5 front and back inflated to 80 PSI . Interesting the difference to FLO
Josh from Silca says the rim should at least 105% of the width of the tire
My rim is about the same as the tire
