I must be using incorrect search strings because I thought it would be something easy to find, but I am not having much luck.
I found this, but not cheap and shipping from the UK - there's gotta be cheaper or at least easier to get.. although I do like that the rear has the chain guide too:
https://www.condorcycles.com/products/condor-thru-axle-fork-spacer?variant=30920843952
https://www.condorcycles.com/products/condor-12mm-thru-axle-frame-spacer-and-chain-keeper-tool?variant=46580014252353
I do like that with the above, you still use the bike's thru-axle so that it is both solidly attached, and the thru-axle itself is stowed.
Versus this plastic protector I also found that just pops in the dropouts:
https://www.orucase.com/...thru-axle-protectors
What are people here using to protect the frame with no wheels mounted during travel?
T. Guertin / Spocket
