Hi,
I just built my Felt IA Advanced (switched from off-the-shelf 105 to SRAM). Like many others, the missing internal hydration system bothered me. Unfortunately, the Specialized Fuelselage bladder is not available anymore, so Fulcos solution is not an option. But I found out that the Canyon X Hydrapak bladder fits quite nicely.
I designed and 3d printed a cover that can replace the Felt CalPak. The design should be final (see pics), but the real thing will of course be in black. You can click in a Canyon Hydrapak and even have room for a gel (but not much more). Installation is relatively easy: insert the Hydrapak in the cover and the frame, click the rear end of the cover in the frame, and secure it with a screw.
You can refill the Hydrapak easily from the top. I did not measured the volume yet, my best guess is 0.5l with the 700ml Hydrapak. I am not 100% sure if the "gel chamber" fits for every frame size - I have a 58. So I'll build a flat cover, too.
If everything tests out ok and if anyone is interested, I can try to make that thing available.
