WTB: 165mm Crank Arms
I have a 2012 Cervelo P2 with 170mm Gossamer crankset 52/36.
I’m looking for 165mm arms, but I’m not sure about compatibility. Will any crank arms work or does it need to be compatible with my bottom bracket?
Re: WTB: 165mm Crank Arms [jordanjwalter] [ In reply to ]
If you are willing to swap BBs, almost any 24 mm spindle cranks will work.
If you aren't, only Rotor and Shimano make cranks with spindles compatible with your current BB.
Also note that most cranksets don't have standalone crankarms, as the drive-side crankarms are often integrated with the respective spider. Rotor is an exception to this, as are cranks modified for SRM power meters.
Not sure, but I thought I had some, but will check and look at the size.
I have a few 165mm crankset available:
-Sram Apex GPX
-Rotor Aldhu BB30
-Rotor Flow BB30
Re: WTB: 165mm Crank Arms [SucabStunna] [ In reply to ]
SOLD I have a 165mm Force22 110BCD (50/34t currently installed) gxp crank that needs a home.
Do you still have the 165mm Flow?
Re: WTB: 165mm Crank Arms [geetee] [ In reply to ]
Yes I still have those cranksets available
Do you still have either rotor crank available?
Thanks 🙏
USAT L2 TriAUS L2 UC Irvine head coach "The human foot is a masterpiece of engineering and a work of art."
Leonardo da Vinci
Re: WTB: 165mm Crank Arms [Yakie54] [ In reply to ]
Yes, the Rotor cranksets are still available
Re: WTB: 165mm Crank Arms [ahumblecycler] [ In reply to ]
Is that a 24mm? Would it fit on a Giant Revolt?
Cheers
Jake
Leonardo da Vinci
The Rotor cranks I have are BB30, so you'll need to get another size bottom bracket if your frame is compatible.
What do you want for the Aldhu arms?
_______________________________________________________
"...Rocketbrother for being fast responses, shipping fast, delivering high quality packaging and products. A pleasure..."
"...rocketbrother is an extremely reliable seller and very knowledgable".
"Bottom line, if he posts something, buy it! A+ seller by a long way..."
