Help installing brake rotors on Hed Jet's
Picked up a brand new set of Het Jet 90 disc wheels and the spline for the front disc has a double-wide tooth on it. Is there a special shimano rotor for this? I'm trying to install RT-MT800's. Rear hub just has a normal spline pattern and installed fine.
Thanks.
Scott
Re: Help installing brake rotors on Hed Jet's [WiScott] [ In reply to ]
Sounds like a defective hub.
Front and rear spline patterns should be identical. Can you post a picture?
I have this front wheel and literally put on the brake rotor last night. There is no double wide tooth. Call HED, it sounds like a mistake.
Re: Help installing brake rotors on Hed Jet's [fredly] [ In reply to ]
Thanks for the help...looks like I received a defect:
Yup, that sure looks like a defect. Give HED a call.
You're welcome.
Re: Help installing brake rotors on Hed Jet's [jimatbeyond] [ In reply to ]
Thanks to you too Jim…didn’t mean to give Fred all of the credit!
Scott
Wow. surprising that it made it through the production QC, or the installation.
