Quote:
When was last time you put a new chain on it? It’s it been a while (more than a year) put a new chain on. If it’s a recently new chain refer to what others said above. New chains are cheap compared to replacing a worn cassette and since you are putting a new chain ring on, treat it to a new chain.
For sure this. At minimum, always check the chain elongation before swapping rings. If it's more than slightly elongated, you'll put a big dent in both the life of the ring and the life of the chain if you don't swap the chain.
But be really cautious with purchasing new chains these days. There are an incredible number of counterfeits floating around, and it isn't easy to tell the difference if you don't know what you're doing. Until they fail to work correctly, or fail under load.
*Definitely* do not buy something like a Shimano, SRAM, or Wipperman chain on Amazon or Ebay unless you know it's coming from a reputable source.
Coaching and bike fit -
http://source-e.net/ Cyclocross blog -
https://crosssports.net/ BJJ instruction -
https://ballardbjj.com/
