Anybody else used this system?
Basically a pocketed sweatband system with (re)freezable pouches that slide inside them, designed to be worn in the usual areas to assist with cooling. The pockets can then be used for gels once the frozen pouches are defrosted.
Probably limited use in races, unless you're doing a hot, supported extreme for example, but look good for indoor, and possibly even runs up to a certain distance.
https://nopinz.com/product/subzero-sweatbands/
The pouches are also compatible with their suits and baselayers.
