Titanflexr wrote:
Superimposed saddle for perspective:
It's also quite possible that they did a run with the saddle and pads as far forward as the rig would allow just as a trial, but this is not an actual position they were considering, just IG bait.
Thanks for this image.
Apparently he is in the limit of the rule, within +5cm (the Ironman rule, not the UCI, of course).
Is it something they are going to test also outside of the wind tunnel ?
To improve SCx by lowering head / shoulders without compressing too much the hip / femur angle, it make sense to go further "in front" of the bike, in the limit of the IM rule.
Apart from the mechanical issues, it does change a bit the balance and driveability of the bike, and maybe have some impact on the muscular / confort aspect.
Anyone here have been experimenting this (tinkering with the +5 cm) ?
Personally, when I moved from UCI rules (TT, Pursuit) with saddle at -5cm and aerobar tips at +75cm (quite a constraint for a 6' with long arms) to saddle around zero cm and aerobar tips around +85cm, it was quite a relief :-)
We will see pretty soon if Blu evaluate positively the balance between (aero ?) gains and confort / muscular impact :-)
