Jonboy wrote:
To get the level of a saddle where do you place the spirit level?
Is it placed on the full seat?
Is it a third of the way in from the rear?
Thoughts please.
I use the full saddle, but it really doesn’t matter much as long as you’re consistent. It’s easiest to be consistent if you use the full saddle, I place a rigid straightedge on the high points of the saddle then use a phone app to measure. Most saddles are made to be run level, but if you’re happiest with 1-2 degrees down bubble, then do that.
A handful of saddles, like SMP, should only be measured on the front section because of the extreme curvature.
Swimming Workout of the Day: Favourite Swim Sets: 2020 National Masters Champion - M50-54 - 50m Butterfly
